Old 12-27-2007, 09:02 AM   #12
texwayne
if you depress the clutch while still on the throttle the rapid release of pressure in the drive train when the clutch disengages will cause a loud "clunk". this only happens in lower gears where the engine RPMs are a lot different from the axle RPMs. in low gears your engine torque is multiplied quite a bit. the engine and transmission twist on their mounts. when you disengage the clutch without releasing the pressure, all the parts that twisted slam back into place. it's not a good thing.
03 Boxster S | EVOMS intake | PSE | B&M shifter | Softronic ECU tune (traded-in)
03 911 C4S | Softronic ECU tune
texwayne is offline   Reply With Quote
