I could also use some clarification about 'turret oil'. I have the service manual and there is no mention of 'turret oil'. Only 'transmission oil' and 'gear oil'.
Also, the manual says to access the drain/fill plugs you need to remove the 'transverse strut panel'. Can I assume that is a protective panel somewhere near the middle of the undercarriage?
Brucelee, I'm not sure what the color is called. I've looked at the long list of porsche names and by process of elimination I'm guessing it is Zenith Blue. I'll have to check the codes.
