Old 12-19-2007, 01:35 PM   #3
saaber
Originally Posted by bmussatti
A few members have used Red Line and report good results.
www.redlineoil.com
http://www.redlineoil.com/products_gearlubricants.asp
Used redline MTL on a saab turbo 5 speed in the past and it made a night and day difference in shifting and the car only had 23k miles. In the boxster 6 speed though, I am not happy with the 75W90NS, it's too notchy. I know the 75W90NS is what redline recommends but I might give them a call and see what might work better.
Redline says the "cocktail" of 75W90NS + lightweight gear oil is no longer needed because the newer 75W90NS has the friction modifier (or whatever additive it is) that you used to get from the lightweight gear oil. But I am halfway tempted to try the cocktail because it would be easy to do. Just remove less than 1 quart of existing fluid and add 1 quart of the lightweight oil.
In theory, MTL (70W80 I believe) should be even more notchy than the 75W90NS but it sure did wonders for that saab (saab went from notchy to liquid smoth instantly). I am thinking I may try MTL via the pump method (saves labor of removing triangle plate on bottom) and if it doesn't work I am only out less than $30. For an experiment that would be a bargain compared with big bucks to get dealer/indy mechanic to do a proper drain and fill. My guess is I will go back to the factory fill even if I do try the MTL experiment.
saaber is offline   Reply With Quote
