Thats weird cause have too much negative, i forgot what the alignment machine said was perfect but it does give a range and in the middle of that acceptible range is the sweet spot.... the perfect camber and with my camber bolts pulled all the way out to towards the fender, Still not good enough... Maybe my lower control arm bushing at the chasis if warn out... that would allow the control arm to stick out little more than it should, i guess.
