Old 12-16-2007, 07:40 AM   #4
[z0ne]
Send a message via AIM to [z0ne] Send a message via MSN to [z0ne]
Originally Posted by Aron in T.O.
The alarm goes into "sleep" mode if the car hasn't been started for 5 days IIRC. You should be able to open / unlock the door w/ the key and start the car as normal. If once you have opened the door w/ the key and the car still will not start, then there is a problem. Are you sure the batter has a charge?
**7 days.
If your 986 hasn't been turned on for 7 days, the car automatically disables the remotes. You've gotta go in and turn the key in the door. After that, you should be all good.
[z0ne] is offline   Reply With Quote
