Old 02-02-2005, 06:25 PM   #4
98blackboxster
How do you know you have a bad maf? did the dealer read the code? What caused the maf to go bad? Depending on what teh problem is you could just correct the problem on the MAF you have. Is there something on the sensor? Like the oil from a K&N? Debris? I had a problem with mine and if you let the maf set in some rubbing alcohol for a few hours and than let the alcohol evaporate overnight it cleans it pretty well. Of course this is just what has worked for me int he past.
98blackboxster is offline   Reply With Quote
