The alarm goes into "sleep" mode if the car hasn't been started for 5 days IIRC. You should be able to open / unlock the door w/ the key and start the car as normal. If once you have opened the door w/ the key and the car still will not start, then there is a problem. Are you sure the batter has a charge?
