Old 12-15-2007, 12:22 AM   #10
CJ_Boxster
Send a message via MSN to CJ_Boxster
Originally Posted by brp987
If you have oem litronics but don't like the color, or if your litronic bulb burns out, can you use the bulbs in this kit rather than buy the oem bulbs which I understand are $250/ea?
What do you mean by size? Does "H7" relate to size?
H7 is the size of the bulb for a non-litronic headlight assembly, if you want to replace your factory litronic bulb, you need to ask the vendor for a replacement DS2 bulb which is what litronics are which is No you cant use the ones in the kit, but the vendor does carry the DS2 bulbs for our litronics... you'll have to email them and ask for pricing.
EDIT: i think its called a D2c bulb for litronic replacement bulbs... A way to check is to remove the bulb from the housing and itll say what type on bulbs housing.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
