Old 12-09-2007, 06:24 PM   #1
CJ_Boxster
Send a message via MSN to CJ_Boxster
Check the tire pressure. 29 psi in front and 36 in the rear, if its off it will effect the way it handles bumps on the road... Too little air and it'll feel alittle slugish, too much air and the front & rear end will bounce around on every crack, bump or bubble gum wrapper on the road and your steering wheel while wiggle like your tire balance is off while at freeway speeds.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
