Old 12-06-2007, 11:18 AM   #7
chaudanova
Originally Posted by Bob O
The switch you need is an Audi/VW part, (the Audi logo and part number are stamped on the side of the switch) which, if you get it at the Audi/VW dealer will be significantly less expensive than getting it from the Porsche dealer, or it was when I got mine anyway. Around $35. The Audi/VW part number is 4A0-905-849-B. Very good instructions can be gotten here. http://mike.focke.googlepages.com/ignitionswitchreplacement . or here. http://industryfigure.com/berkeley/Porsche/ignitionswitch.htm Its a little cramped under there but not too bad once you figure out where those darn little screws are and how to hold your left arm jusssssttttt so to get to them. Took me less than an hour start to finish. Be sure to disconnect your battery and be equally sure you have your radio code!
Bob
I believe the Audi/VW switch is the older plastic style switch. Porsche has revised the switch, and the newer one is the one that I posted the link to in my previous post. I just replaced my switch a few months ago with the newer type.
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
