Old 12-05-2007, 06:25 PM   #12
jmatta
No need to replace the rears if not overly worn. You will typically go through two sets of fronts for each set of rears. Also, no need to replace all four unless you are changing to a different compound. I would recommend bleeding the system, however. The fluid is hygroscopic and will absord moisture over time.
Missed a post, as I see you did bleed the brakes.
