Old 12-05-2007, 12:48 PM   #1
porschedude
yeah, i dont know why they list Mintex as OEM but it doesn't matter...you can get that pad...it's good stuff. Also, you don't need to change the rear pads if they are still ok. you can use the old brake shims (to prevent vibrations) but you have to remove them from the old pad and perhaps super glue to the new ones...the old shims have a few dimples on the surface i had to flatten out with a mallet in order to use again. also, you don't need to remove the Brembo calipers to change the brake pads unlike a bmw.
porschedude is offline   Reply With Quote
