Old 12-05-2007, 07:49 AM   #2
porschedude
Try Pelicanparts.com, ************************************************************ or ********************************************************************************************. I recommend Mintex red box semi-metallic cause they don't release much dust. The factory OEM brakes are terrible with lots of dust. At 33K miles, I would not replace the rotors. I don't see why you need new clips or other kits...just change the pads. The dealer will typically change everything under the sun (unnecessary) and charge 800-1000 for each axle but you can DIY the pads for $50 each axle, which is all you need.
porschedude is offline   Reply With Quote
