Here is what you do. You use the tool provided in your porsche tool kit and rotate the 5mm release bolt back towards the car and you will hear a plastic pop sound and the headlight will move up afew centimeters, then rotate the tool forward gently and that will push the headlight out alittle more for you to grab with your hands and pull the headlight the rest of the way out.
