Old 12-01-2007, 05:22 PM   #2
John V
Ramps suck. Not enough clearance under them to do much of anything.
The rear is easy enough to jack up since there is a center jacking point. The front is more of a challenge. I notched the undertray in my car so I can use the factory jack point for the floor jack, and put a jackstand under the front subframe, slightly inboard of the jack.
You have to jack the car one corner at a time using this method, but it works fine.
John V is offline   Reply With Quote
