Old 11-30-2007, 04:03 PM   #2
Burg Boxster
you can use the jack in the front trunk to get it up but.....
ABSOLUTELY UNDER NO UNCERTAIN TERMS SHOULD YOU CRAWL UNDERNEATH TO WORK OR EVEN LOOK AT THE CAR UNLESS IT SECURED ON JACK STANDS and/or ramps.
Working under a vehicle supported only by a jack is senseless as you never know when it could give way - regardless of jack rating. As a guide, always always always use either ramps, jack stands, or a secured lift when working under any vehicle that weighs more than you
