Old 11-30-2007, 02:06 PM   #4
blkboxster
Guest
Posts: n/a
Originally Posted by schwank
I have the 18" factory option turbo twist rims on my S. I just ordered a new set of Bridgestone 960AS Pole Positions from TireRack in the following sizes:
F: 225/40-18
R: 265/35-18
As you can see the sidewall height number drops down when using a wider tire. But if you do the math, the sidewalls are less than 3mm variance since that number is actually a ratio.
Hope that helps!
So will F 225 40 18
R 265 35 18 which i think im going to order will fit my rims??
