Thread: Blown Engine
Old 11-29-2007, 06:19 PM   #19
bmussatti
Guest
Posts: n/a
Originally Posted by randijo
No lease. We own it.
We followed proper break in procedure on the first engine and we are braking in the new one the same way. We keep the RPMs under 4000, no full throttle starts, and try to vary the speed for the first 2000 miles.
The old engine only had 12000 miles on it after a year and a half. According to the maintenance schedule it wasn't yet due for an oil change. Do you really think changing the oil once a year will prevent engine failure?
Randijo, good job on doing the proper engine break-in. Not an easy thing to do. Requires great patience! Must be even harder with the second engine, partly because you know what the car is capable of doing, and are more accomplished at driving it.
You should have changed the oil prior to last winter's storage. Did this cause your engine failure? I doubt it.
Let say you are going to keep the car 10 years. And you change the oil yearly. Will this "prevent engine failure"? In a nut-shell...yes. Could something else be the cause (IMS)...sure. If you changed the oil once in 10 years...would the engine fail...my money says yes. What if you change twice? How about 3 times? What is the level of risk you are comfortable with?
Changing oil is cheap insurance. Even cheaper for the many great DIY'ers on this Forum.
Don't forget, Randijo, the oil in our cars does about 40% lubrication and 60% cooling.
