Old 01-27-2005, 02:34 PM   #3
98blackboxster
Originally Posted by Tool Pants
What is the OBDII fault code number(s)? What method did you use to turn off the check engine light? How many miles since you put in the K&N before the light came on? How many miles with the original paper filter reinstalled and do you think the light will not come on again?
Well my OBD2 reader will not give me the code for this car for some reason but this is the only thing that has changed. I could feel a little hesitation immediately after installing the K&N. I would say I put about 50 miles on the car with the K&N in before the light came on? I took it out as soon as the light came on too and replaced with stock air filter. I'll go home after work and soak the stack filter with some rubbing alcohol so the intake mist of alcohol will hopefully clean the MAF. The light has not come back on yet, but there is still just the slightest hesitation.
98blackboxster is offline   Reply With Quote
