DJ, I can help out, there is a section in the owners manual on this, mine was an adendum. One thing I found was the adjusters on my lights were reversed from one side to the other and didn't match the directions. That is to say the lower adjust port on one side was L/R on the other it was up/down and vise versa. Make sure you label the adjusters or be aware of this in case your lights are like mine, (purchased at Suncoast). Anyhow, it's a process that requires patience. I did mine in the summer, left the wrench in the trunk and micro tweaked the lights till I was satisfied, it helps to have someone sit in the car, I think Porsche says 175 pounds of weight without person in drivers seat, where you are supposed to get that wasn't coevered! good luck.
