Old 11-26-2007, 02:32 PM   #1
blackONblack
Originally Posted by blkboxster
Size: 18x8 front/ 18x10 REAR
Offset: +48mm front/ +40MM REAR
and if they do what tire size would i need?
and would i need spacers?? and what size spacers
thanks
These will fit with no spacers needed. I'm running 275's or 285's in the rear. If your car is lowered you may get some rubbing on the inside of the fender wheel out back, you should have no issues in the front.
blackONblack is offline   Reply With Quote
