Old 11-20-2007, 05:28 AM   #2
insite
Originally Posted by arenared
This is not true. The S rotors are 318mm. The base are 298mm which give about a 7% greater front braking bias.
i was referring to the rears. since the rears are the same diameter, with the same diameter pistons, the brake bias would be the same as it is on a stock boxster S. i was inferring that this was a bias Porsche deemed acceptable, so the upgrade wouldn't mess anything up.
I've looked there and elsewhere for years. I have an 'S', so I'm mostly interested in providing the numbers to others when the subject comes up.
i'll see if i can find them.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
