Old 11-19-2007, 08:39 PM   #1
arenared
Originally Posted by insite
actually, the more one increases the braking capability of the front, the less of a need there is for rear brakes.
Actually, the more one increases the traction of the front ..., that is true as you note later. Also, these cars have a relatively low CG, so the weight transfer is not as much as on other cars.
regardless, the caliper pistons, rotor diameter, and proportioning valve are all the same as on the S.
This is not true. The S rotors are 318mm. The base are 298mm which give about a 7% greater front braking bias.
do a search at boxster racing board.
I've looked there and elsewhere for years. I have an 'S', so I'm mostly interested in providing the numbers to others when the subject comes up.
arenared is offline   Reply With Quote
