Old 11-19-2007, 07:21 PM   #14
arenared
Originally Posted by insite
the rears require either an adapter for the e-brake or a special rotor available directly from brembo. this rotor has the base 986 e-brake / hub surface with the correct offset for the 996 / S calipers.
Do you have any part numbers or links? I've searched all things Brembo that I could find and could not find these "special" rotors. I assume the rear rotors are 24mm wide. Thanks!
arenared is offline   Reply With Quote
