Putting it up on jack stands to prevent flat spoting of the tires is an option.
Also want to pick up a battery Tender to keep it charged while it sits there.
You might wan to also crank start her up 10 minutes atleast once a week so the oil gets a chance to recoat the stems of the valves, cams, crank bearings and cyclindar walls. Thats about all you need todo.
