Old 11-19-2007, 01:49 PM   #3
OldBlevins
Do you happen to have a voltometer? If you do, a good first bet would be to make sure you have a decent ground connection to the socket. Even a little corrosion in the socket can block the connection.
I haven't fiddled yet with my boxster's rear light bulbs, so I don't know, but if it's a multi-filament bulb and the running light works, it's probably not the ground. If it's not, my next move would be to use the tester with a proven ground and scrape the probe hard against the hot feed while someone presses on the brake and see if I get current.
Most of the time I have found the problem lies in the socket connections and not in the vehicle wiring.
If you don't have access to a voltometer, let me know and I'll tell you an inexpensive workaround to test your connections.
- Jim
2000 Boxster S, Speed Yellow, Michelin AS/3 tires, 60,000 miles...
... and climbing.
OldBlevins is offline   Reply With Quote
