Old 11-19-2007, 11:04 AM   #2
nightscout
I too am having this issue with my passenger side window. Just stopped working one night (stuck at 1/8" lower than fully rolled up). So far I have checked the fuse, tested the switch and it works fine (tested it by hooking it to the driver side), unhooked the harness and plugged it into a new regulator with no movement. the only thing I can think of is if there is a short somewhere in the line, but that scares me to try and track down. Is there any other points on the system I can check or test?
the window does not move down when the door is open, or when the softtop latch us open.
i have not tried hooking a voltmeter to anything. is there a diagram that would show if there is any power or anything to the harness?
97 triptonic
nightscout is offline   Reply With Quote
