			Brake fade has not been an issue.
But more braking power will be nice.
If brake pads alone can give more braking power which ones do you guys recommend?
Problem with the tip, is sometimes you need to brake hard, when it just autoupshifts before a turn that I had setup at 7000 rpms and use compression braking, its goes a higher gear bu itself and its time to brake hard.
Maybe that's why they are worn out.
