Old 11-15-2007, 04:13 PM   #3
robert scales
Hi Blinkwatt,
I can take a picture, but the cowl I refer to is the area where the battery is; you remove the 2 plastic covers on either side of the battery and you access the area.
The drain I pushed through is the "middle one", just a bit on the driver side of the battery, in the "floor of the cowl.
I was wondering if this area was accessible from under the car if you removed the plastic flat panel running under the center of the car. Someone you may have reaassembled this car may know. I just don't know the body panel configuration on this car.
Thanks, Bob
robert scales is offline   Reply With Quote
