Old 11-13-2007, 12:21 PM   #1
vheidenr
I've changed that hand brake....it isn't so bad...but does require complete removal of the center console. Some of the short shift kits have pretty good instructions on how to remove the center console. The hand brake swap is pretty straight forward once you get a look at it. Just be sure to measure the length of the adjustment screw showing before you remove everything so that you can secure the new brake to the same setting (length)
vheidenr is offline   Reply With Quote
