Thread: so why a 7?
Old 11-10-2007, 08:48 AM   #3
Padawan
How long has it done this? Does the 7 show each time you use the electronic dip stick?
The numbers in the display are used to show the waiting time until the dipstick will function. They are not related to the actual oil level. In this case, it seems as if the 7 is somehow getting "stuck", unless it is also some sort of code used to indicate a problem with the system.
The manual doesn't provide much information except that:
If the whole segment display flashes, there is a fault in the measuring device.
and
The waiting time is displayed by clock C when the ignition is switched on, as a count-down in minutes and seconds.
2000 Guards Red Boxster
There is no substitute.
Padawan is offline   Reply With Quote
