Thread: OBC hack
Old 11-09-2007, 07:02 PM   #3
brian2034
Originally Posted by rick3000
If you have a temperature reading your OBC is on. If not, then it is not on.
Also, the OBC is the wiring of the car under the drivers seat I would highly recommend you do not remove it. That would be very bad because it would disable the entire car. The OBC is not one module.
I did the OBC, it was the best $50 I have spent on my Boxster. And try searching for OBC there are a lot of threads on this.
Welcome to the Forum! You should post some Pictures!
And Good Luck with the Mod!
Thank-you for the quick reply, I've searched this and other sites for the information on the OBC hack and it looks like a easy installation.
But from what I have read, on the 2002 model Boxster the trip meter diplay is where the temperature reading is also displayed and you have to be able to toggle or switch between the displays to view the temp.
brian2034 is offline   Reply With Quote
