Old 11-09-2007, 11:13 AM   #1
Adam
I'm not sure why they have a 2.5L and 3.2L kit already out, but not one for the 2.7L. They said they are going to go single turbo instead of twin? I find that strange since the 3.2L and 2.5L kits use twins. I have never corresponded with the guys at turbowerx so I don't know what all they have to change to make this kit compatible. Turbowerx uses an intercooler and the superchargers do not, so they can boost in a couple more PSI into the engine due to the cooler charge. We are only talking about 6 PSI so even on the high compression engine, it should be fairly reliable I would think. Here's Gary's dyno sheet with base, supercharged, and turbocharges results. He had the S/C on there, but then went to the TT setup. It's easy to see which one gives the best results. Take a look at the torque curve on the turbo!
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
