Old 11-08-2007, 11:42 AM   #11
roadracer311
roadracer311's Avatar
Originally Posted by edevlin
Hey, that is a great site, does anyone know what size parts (tube and ends) we need to get for our cars?
Ed
From earlier posts, it sounds like the center to center measurement for the holes needs to be 22.25 inches and the bolts that hold the plate to the bottom of the car are 3/8" in diameter (roughly, since the original ones on the car are metric).
The web site says that the heim joints add 1.5 inches to each end of the rod, so it sounds like a 19" long rod + a total of 3 inches of heim joint would be 22" (the adjustability would take car of the last 1/4 inch.
Now there's the question of which diameter rod to use, which heim joints. And then, jam nuts will also be needed to keep the thing from adjusting itself after it's installed. The one dimension I don't know is how long the new bolts need to be (the ones that bolt the heim joint to the car).
Given the amount of time involved in figuring all of this out and then not knowing for sure it's going to fit I can see the value in the Canadian-sourced one. Then again... it's sort of fun to figure out.
2003 Boxster S
1995 Ferrari F355 Spider
San Francisco, CA
roadracer311 is offline   Reply With Quote
