The ones I bought are the Rosso 275/35ZR18
Load Index 95 = 1521lbs (690kg) per tire
Speed Rating “Y” = 186mph (300kph) 95Y SL Asimmetrico Treadwear: 220
Traction: AA Temperature: A220 AA A 1521 lbs. 51 psi
They have the same treadwear as the PS2,
I guess they will just have to wear in.
I will put Pzero Rosso up front and see if that makes any change, until then , I guess I will just have to be careful.
James
2002 S
