Old 11-06-2007, 09:01 AM   #13
Perfectlap
Perfectlap's Avatar
Originally Posted by Frodo
Quote: "For a silver car I'm not really big on the carnauba waxes like S100 and P21s. I think those waxes are better for reds and blacks."
Trumped by PerfectLap on a detailing question---imagine that!
Like I said, I don't know what's the best approach on silver. I'm driving seal grey, a darker metallic that, like the reds & blacks, responds wonderfully to carnauba.
Hey PL, I thought you used Jeffs Werkstatt acrylic jet. Do you use both it and the FK1 1000P (which is also apparently a synthetic)? If so, I guess the Werk would go under the FK?
don't get me wrong, S100, Souveran, P21s are a 1000% improvement over bare silver paint. The Carnaubas bring out the glimmer in metallics. I'm just lazy or spoiled on the low effort of silver so I don't put in the effort because carnaubas don't last nearly as long as the acrylic synth waxes that give silver less mettalic sparlke but do give a great wet/glass look, especially at night.
as for Werksttat, I do use the acrylic sealant (Trigger) imediately after the Prime polish(Strong). Generally speaking I find that sealants tend to bond very well with polishes from the same brand. I only do this combination with each season change, its more protection than dressing.
For monthly waxing I use the 1000P as a base because its nuke proof it dries like cement. I could stop here and the car would be protected and shiny for 4-7 months minimum depending on 425 spray coverage. The 1000P is like adding a layer of clear coat, works very well with the spit shine method and I only get out that huge tin (FK1 have issues with portion control apparently) every couple of months or so. I think using 1000P high temp every month would be overkill. A light waxing of FK1 Pink Wax(also in a HUGE tin) for monthly use keeps the shine at 10/10's. Sometimes I'll switch it up and use Souveran liquid wax as my monthly to add a little glimmer or Aqua Wax spray for a wetter look... But 425 is always the LSP (last step product). Kinda crazy when you think about it but I'm pretty sure the paint will continue to look new for another ten years at least. I'm always amazed when I pull up next to a Honda or Ford that is no more than 4 years old and is already rusting or the paint is dulled down to the base layer.
BORN: March 2000 - FINLAND
