Old 11-01-2007, 08:09 AM   #12
Dr. Kill
Originally Posted by Kirk
CJ, I agree 100% that someone probably pried the lights out with a screw driver rather than popping the hood. There's only one metal piece that holds them in, so all they would have to do is pry hard enough with a screw driver to break either the mount or the light.
Before you settle with the insurance company make sure you have the car checked out carefully by a professional. I don't know how they could pry out the lights without bending some sheetmetal. I know you see scratches, but the metal also may not be straight. As you mentioned, the headlight mount may be broken too (which may require removing the fender to replace). What about the wiring harness, did they cut that?
Again, I'd check everything out carefully so that you make sure you're not shorted on what repairs are required.
Also, you said they stole the yellow egg yolk lights. I could have sworn you hard clear halogens in there though.... right? Wink, wink, nudge, nudge
Kirk
I think everything in this post except for the insurance fraud is good advice.
Happy Motoring!... Tim’05
http://i153.photobucket.com/albums/s..._kill/Siga.jpg
Dr. Kill is offline   Reply With Quote
