Old 10-29-2007, 10:51 AM   #9
Perfectlap
Perfectlap's Avatar
Not sure if I mentioned this but in case anyone else is reading... try this method for waxing, helps reduce friction, elbow grease and give a better result imo.
1- spray the surface with a quick detailer (I like FK1 425)
2-apply your paste wax of choice with a foam applicator, spread the wax evenly (not in circles). The quick detailer sort fo "melts" the wax evenly.
3-let it dry while you start the 2nd panel.
4-respray the 1st panel
5-using speed, not pressure, buff out.
try using a super soft buffing towel if you have one. Or use the short (non-furry) side of a microfiber towel. Waffle weave is great too. If your layering, let it cure for at least 6 hours.
BORN: March 2000 - FINLAND
