Old 10-27-2007, 10:48 AM   #4
pk2
Originally Posted by bmussatti
Could still be the ignition switch. Could also be the car's ground wire.
Thanks,
The ignition switch is still on the table. Dosn’t quite jive with the fact that the starter cranks (but doesn’t start) when I jump the relay…but that fact doesn’t jive with wiring diagrams either (as best I can see)
Though I didn’t see any signs of corrosion on the ground straps I bumped into, I’ve clean 3 out of 7, all those in the proximity of the pertinent components I checked.
Sounds like voodoo but this has all happened while the battery had a charger hooked to it. 1 time was when I didn’t have it on charge and ran the battery down and recharged it. Most recently, I’d left the radio on all night with charger on…only pertinent variable I see in the proceeding problem free 2 years.
Regards, PK
pk2 is offline   Reply With Quote
