Old 10-26-2007, 09:33 AM   #2
saaber
Originally Posted by linkjones
Might be a leaky resevoir. I'm experiencing the same problem but haven't done anything about it yet as I just parked mine for the winter, you can order the resevoir from ************************************************************ for about $500 but you may want to check your connection hoses on the side. While you're at it you may want to replace your coolant level sensor as they can get gunked up, it's about $30. It goes on the bottom of the resevoir.
Zerex makes an acceptable coolant that is approved by Porsche, I don't know the name of it off the top of my head but if you do some research you'll be able to find it.
This seems to be a common problem, let us know if you get it resolved.
Just bought the reservoir for $225 from these guys with free shipping:
http://www.sjmautotechnik.com/
They also have the pink Pentosin "lifetime" antifreeze which after extensive research I believe is the product that porsche rebrands and quadruples the price. Pentosin (pink) is the factory fill for audis and vws. It costs $11.42 per gallon compared to $50 per gallon for Porsche-branded.
saaber is offline   Reply With Quote
