Old 10-23-2007, 01:33 PM   #10
Bobiam
Bobiam's Avatar
Originally Posted by Bobiam
I'll likely use the black zip ties since my roll bar is black. Will they slide under the plastic trim on the front of the roll bar so as to nearly be invisible???
OK.... did it just now. Drilled two 3/16 holes in the bottom frame of the center windstop and snaked zipties around the rollbar. Also added a smaller ziptie around each outside edge around the rollbar.
The ties on the center piece also lean a bit on the plastic frame giving it a tightening effect as well. Now I will not have to worry at over 130mph... . Won't be makin' any Porsche litter on the highway now.
Regarding security, unless someone has a knife or snips plus a little "stand there" time, they can't just grab parts and run.
You judge the photos.
Good to get all the forum ideas...
Bob
Bobiam is offline   Reply With Quote
