Old 10-14-2007, 08:43 AM   #2
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
No tricks really. Just jack the car up at the front driver's side wheel well area. This will give you enough room to pull back the wheel well liner, as the tire would be in the way if you don't jack up the car.
Then, remove one of the plastic nuts on the rear section of the wheel well, and 2 of the plastic rivets. This will allow you to pull back the wheel liner enough to see the rubber hose that connects to the nipple of the washer fluid tank. Reconnect the hose to the tank nipple, and then put a small hose clamp on it to prevent this from happening again.
I just did this 2 weeks ago, and the hose hasn't fallen off again. Good luck.
