Old 09-24-2007, 08:31 AM   #4
Boxter
...it goes away when the car is warmer because I believe the coolant level rises.
If you checked the level and it is Ok then I can't help you...
...I know that symptom lead to a cracked coolant tank in my case. Its the old crack under the tank, wet spot near the passenger rear tire, coolant under the carpet in the trunk bit.
If it is a cracked coolant tank, its an $800 dealer repair that some have completed themselves. However I have heard that it gets a little funky/difficult dealing with the lines that run through the fire wall.
...good luck with your diagnosis.
http://home.comcast.net/~jmpfleet/Cars/m3r.JPG
Current - 04' M3 SMG Convertible
SOLD - But never to be forgotten 98 Boxster
Stock w/19" Wheels, stealth K40 front and rear
Boxter is offline   Reply With Quote
