Old 09-20-2007, 09:42 AM   #2
blinkwatt
Send a message via AIM to blinkwatt
Originally Posted by ChrisZang
now I have to find the DYI for removing the rear bumper, I know they're out there somewhere
You need to start by removing the rear spoiler first.
-Raise the spoiler manually w/ the switch near the dead pedal(or the rear spoiler switch if you've done that mod)
-Open the rear trunk so you don't mess it up while work
-Get a center punch,small nail or something you can tap the middle of the three rivets out with
-remove the rear spoiler cover
-Remove the two bolts located inside the spoiler by looking downwards within the spoiler
-Lift and remove spoiler
Now removing the rear bumper
-Remove the bumperettes by releasing their bolt. You can see the bolt when you get on the ground and look on your back
-remove the wheel well housing screw, 1/side
-remove the three screws located on the bottom of the bumper, 3/side
-remove the screws from the license plate lighting,2/per light
-release the lights from the bumper
I think that's all it was,pretty darn easy. I can double check tonight to make sure I listed all the steps.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
