Thread: Wet again
Old 09-17-2007, 09:09 AM   #2
Cloudsurfer
Bob-
I think I may be in a similar boat (no pun intended) as you are. I don't have buckets of water, but the other day in a hard rain I had some slight moisture on the rear carpet of the driver side, and a bit under the door speakers carpet (which in my case, is very custom audio).
Can you enlighten me on the door drainage system, both within the door and the jambs (since it seems you understand it very well)?
It sounds like you may be scratching your head, or doing the target painting, since from what I understand, it seems you've hit all the points of water intrusion, so if you can't find anything, I'm not sure what's left to miss?
Patrick
