Old 09-14-2007, 07:38 AM   #1
cmarks20
Exclamation Lighting system woes
Morning guys. I have a couple of issues going on:
1. My driver's side headlight went out last night. I replaced the light, but now none of the lights on that side work.
2. My front turn signals don't work at all, though the back ones are fine. They worked perfectly yesterday, but since issue #1, I get nothing. I checked the fuse, which turned out to be just fine. Is there a solenoid I should check?
3. When I turn on my foglights (which also don't work anymore, on either side), I get a strange buzzing sound that seems to be comming from behind the light "dial." The buzzing stops if I push the dial back in to run my headlights without my fog lights.
I did some searching on the forum, but didn't come up with anything related. If anyone has experienced any of this, or suggestions on things to try out before I break down and go to the dealer, it'd be greatly appreciated.
2000 Boxster - Arctic Silver
cmarks20 is offline   Reply With Quote
