Old 09-10-2007, 09:20 PM   #1
Cloudsurfer
I'm not sure as to wiring in the HKS computer, but I can tell you that for oil pressure you will need a Carerra oil pressure sender, which is easy to swap, and one more wire for actual pressure signal, not just the idiot light. I believe the factory temp sensor will give you a readout. As to injector size, not sure, nor am I sure where to grab those other signals from. I would think you could figure all this out from the bentley diagram? I've used mine with much success for wiring
Patrick
