Old 09-03-2007, 07:58 AM   #10
djomlas
Send a message via AIM to djomlas
Originally Posted by williamsF1
Hi Djomlas,
I can see you also painted the frame around the AC and CD, the upper center frame. I have a PCM display instead but I would like to replace my frame with a new one (the one I have currently has a few marks).
I have just ordered a new frame + two smaller frames where the buttons are but I cannot figure out how to replace this. Is it hard ?
Do you know of a guide on how to remove it ? Do I have to take out the double din PCM unit ?
once you pull the 2 side frames or whatever with the buttons, remove the wires from the buttons and put the frame aside, do the same for the other one.
you will then clearly see how its all held together, i believe there are only 3 screws holding the whole thing in place, then you can pull it out, and disconnect all the wires going to the radio and ac, or whatever else you have mounted up there. if you have AC in there like i do, you need to remove the black plastic case around the whole thing, and its held by 2 screws and these little brackets that just fall out.
http://i34.tinypic.com/157yslk.jpg
"I couldn't find the sports car of my dreams, so I built it myself." ~F. Porsche
Gemballa springs::litronics::Eurotech 18s(275/225)::B&M::MOMO wheel::
exhaust cutouts::EVOcoldair intake::OEM smoked tails & sidemarkers::
colormatched bumperettes::Top Speed Pro-1 exhaust::
my cardomain/pictures page
djomlas is offline   Reply With Quote
