Old 09-01-2007, 08:20 AM   #2
husker boxster
husker boxster's Avatar
Randall has pointed you in the direction of the least expensive wheels. I searched for months earlier this year and couldn't find anything cheaper. TireRack is another place to look, I just didn't like the offerings they had.
Be sure to get the proper offsets before you pull the trigger on buying anything. Don't want to make an expensive misktake. The factory sizes & offsets are:
F 7.5x18 50
R 9x18 52
Wheel Dyn sells 10x18 47mm offset rears which will fit. The e-brake cable needs to be pinned back.
Good luck with your search.
1989 928 S4 5 spd - black
