Old 08-23-2007, 05:20 PM   #2
Burg Boxster
yes front bumper cover removal is required. Should install replacement (high and lows at once) and tilt the other way (water likely got in your existing ones due to the angle and caused them to go bad. while replacing - you should also clean out your radiators.
instructions for all are in the archives - just search on any of the following:
cleaning radiators
horn replacement
good luck.
